i have run squidex with iis and i create a schema for blog page but i dont know how i insert this page in my project code ( code is mvc core )
what can i do ? what the steps
thanks ,
You can access the blog page through the API.
In PHP you can use “curl”, and in Javescript you can use “fetch” to query the API.
https://docs.squidex.io/02-documentation/developer-guides/api-overview/authentication
@ahmed_hassan Take a look at the Squidex.ClientLibrary package: https://github.com/Squidex/squidex-samples/tree/master/csharp/Squidex.ClientLibrary
Add the respective NuGet package to your project.
Try to follow the README.MD there although the Readme is a little bit outdated in terms of step 3 (In https://github.com/Squidex/squidex-samples/commit/c1e64071db7d3d4be829e368531674f03ec42730, @Sebastian marked the methods used in the README.md as obsolete)
My recommended way to use Squidex.ClientLibrary
- You don’t want to create the client classes yourself. Instead, clone https://github.com/Squidex/squidex-samples/tree/master/csharp/Squidex.ClientLibrary, open
Squidex.ClientLibrary.slnand set CodeGeneration as your startup project. Enter your credentials there. Run the code, take the generatedGenerated.csfile and insert it into your ASP.NET Core MVC project. - Initialize the client manager
- Adjust this code to your schema’s name:
var httpClient = clientManager.CreateHttpClient(); var yourBlogClient = new BlogClient(httpClient); // name of the class depends on your schema's name and, therefore, the generated classes are called var yourData = yourBlogClient.QueryBlogContentsAsync(); // replace `Blog` with the name of your schema
from where can i get my credentials of my blog schema
thanks,
@ahmed_hassan
In cloud.squidex.io select your app, go tot settings -> clients and use the credentials shown there.
I created to pull request to update the documentation: https://github.com/Squidex/squidex-samples/pull/39
