- [ ] Checked the logs and have provided the logs if I found something suspicious there
- [X ] Documentation issue or request
We moved an installation of Squidex that was on HTTP to a production server and it is now on HTTPS. When you enter your user credentials and press login, it stays on the login screen and loops.
After login it should take you to the dashboard
It happens with the only login which is the admin login at the moment. The error we get is:
“. . .was loaded over HTTPS, but requested an insecure XMLHttpRequest endpoint ‘http://cms.domainname.com/identity-server/.well-known/openid-configuration/jwks’. This request has been blocked; the content must be served over HTTPS.”
- [ x] Self hosted with other version
- [ ] Chrome (desktop)
- [ X] Chrome (iOS)
- [ X] Safari (desktop)
We set the Login redirect to True. If you have it on false and you land on the domain you can click the LOGIN button which opens up the popup. When you put your credentials in the popup the popup closes and it stays on the landing page
