Hi team,
Is there a character limit for the fields category, product, and description?
Thanks!
Hi team,
Thanks!
In Squidex you create your own schemas. So you go the schema section and a configure validation rules there:
If you do not have permissions for that, you have to ask the owner of the app or your developers.
If there is neither a minimum nor a maximum length established, there should be none whatsoever, right?
Thanks!
Yes, exactly. There is a maximum of 10 MB or so which is like 10.000.000 charachters
