Import content to nested reference field
I am using the CLI command (content import) to import content. if it’s a reference field at a top-level, then I am resolving the reference id first and working smoothly. however, I have some schema where the reference field is lying inside the array element. I have tried various paths, but not succeeded. is CLI supports this nested level content import for the reference field? if yes, is there any trick to resolve this?
Do you mean the CLI sync command?
I mean CLI content import command.
It should work, I am not sure. Can you show me some paths?
i tried lots but i found this one very close
  • contacts.iv.0.city.iv.0=referenceid
It should be
contacts.iv.0.city.0
it’s working now, Thank you very much.
