I have content spread across numerous schema, each of which can go through numerous changes within a user session. I’d like to be able to query Squidex to give me a list of all those changes so that I could sort into chronological order and allow a step by step undo. Is there a way to query an app for this type of information ?
There is this endpoint that is used in the frontend: https://cloud.squidex.io/api/docs#tag/History
A channel is a prefix like schemas or contents or contents.{id}
We could also make improvements to define the actor per query.
Thanks Sebastian, I’ll take a closer look at the api.
Thanks again Sebastian for taking the time to answer. Was hoping to get some follow up answers however:
- Is there a predefined timespan for which history records are returned ?
- Or is there a trigger for clearing out history records ?
- Is there already a mechanism in place to delete a change made to contents (maybe a way to delete a version based on version number)?
No, just the last 100.
No, history is never deleted.
No, only one version of a content exists. If you want to implement undo, you have to implement the undo operation manually. Technically we could implement something to delete the last X events or so and then rebuild the content from there.
Late reply on this, sorry, but this functionality has reared its head for me again.
Is there a way to get the meta data or the history event for changes made more than 100 events ago ?
From what I can tell, the only way to do this would be to download and extract the backup and examine all the changes in the json files - which I really don’t want to do.
