In GraphQL sorting features, the ordering feature ç, ş, ğ, ö, ü does not work in Latin alphabet characters (for example: Turkish). I believe this should be improved and corrected.
Sounds like a bug actually or a limitation of MongoDB. Do you have more details about that?
of course, for example, I create a schema. to include countries and provinces of countries;
Country: Turkey > District: İstanbul
Country: Turkey > District: Şırnak
Country: Turkey > District: Ankara
Country: Turkey > District: Lüleburgaz
Country: Turkey > District: Mersin
Country: Turkey > District: Bursa
Country: Turkey > District: Zonguldak
If I say sort by district in graphQL, it cannot sort the fields that start with Turkish characters and puts them at the end of the data.
Result:
Ankara
Bursa
Lüleburgaz
Mersin
Zonguldak
İstanbul
Şırnak
is this not correct? I guess they are just sorted by numeric value inside the unicode table.
In other database you have to define the collation. Or you have to normalize the data.
I got it, but I am not sure if I can do anything about that.
EDIT: I could define a new operator for collation. Not sure if that would work.
I have implemented that. There is a new collation option now, where you can define the language code.
