When the Asset field is created in the schema, a very large field is added to the view. Another view option may be to choose a simpler view and a view that takes up less space on the screen. We often need this.
Good point. Do you have an idea? Especially when no assets are added a small view would make sense. Perhaps the same for references?
A simpler look would be nice, especially for single file uploads. It can be considered for many points. In fact, a simplified version is provided with the Add Component button. Maybe a simple look can be created based on that.
