Please can you add a config switch to disable [PII is hidden] from identity server for debug, to make it easier to resolve configuration issues. At the moment any URI misconfiguration is quite difficult to trace.
Thank you
Thank you
Sure, can do that…
I have added this setting: https://github.com/Squidex/squidex/commit/4b74865702e1a3de58b3c8f9442decea74c2d51f
Thank you so much
that is perfect
I noticed a config typo and submitted a PR - I hope it helps.
Thanks again!
Yes, have accepted it
