- [X] Documentation issue or request
More of question and/or possible loophole here, really. I was thinking about adding a base64 representation of a thumbnail for uploaded image assets. This works to the extent that I have a rule that triggers on Asset changes and pings an external API that then creates the thumbnail and persists it to the a meta data field, so far, so good.
The base64 string, even for a 50px thumbnail ends up at 2000+ characters, which makes the Asset editor complain as the max length for a metadata field is 1000. The API allows saving it, but the UI complains. Is there a reason for the 1000 character limit, or can it be removed? Is storing larger strings as metadata a bad idea?
- [X] Self hosted with docker
Version: 6.0.1
- [ ] Chrome (desktop)
- [X] Edge
