Read the following guideline: Troubleshooting and Support | Squidex. I understand that my support request might get deleted if I do not follow the guideline.
Used code blocks with ``` to format my code examples like JSON or logs properly.
Regression (a behavior that stopped working in a new release)
Bug report
Performance issue
Documentation issue or request
I’ve script to check reference duplicates, but for that I need to send getJson to fetch contents
I’ve complex schemas I have base schema A with SKU, and 3 others schemas which have reference to the schema A, anyway if you can migrate fetch to the scripting engine to give more flexibility(Scripting request bearer token not working - #4 by Sebastian) that would be enough to me
@Sebastian Is there a way to find out what features are in the cloud version and what are not yet deployed? I know you mentioned that the releases from cloud and github are decoupled in another thread, but I guess it would be helpful to have this information transparent somewhere. In the case of getContents() it seems like it’s not available in the cloud version right now? Thanks for any feedback!
