[IMPLEMENTED] Preview URL for schemas
Hi!
First of all, let me thank you for a really awesome product. I’ve been searching for a long time for a suitable CMS for our React migration, and I think that I’ve finally found what I’m looking for. Squidex ticks all the boxes of what we require from a CMS and we’ll most likely be starting to implement it in our test environment soon.
The only thing that I’m missing when comparing it to other CMS products out there, is the possibility for the out editors to preview content for specific components before publishing it.
The way I insvision it is that you would for a schema supply a preview-url, e.g. “http://ourlocaltestenv/reactcomponents/blog-post-component”. Then when you create/edit content for that schema, you would get a preview-button that would take the user to that preview url, with an additional query-parameter for the content id, e.g. http://ourlocaltestenv/reactcomponents/blog-post-component?contentId=ea66f5ea-7b72-4d31-965a-8def8a3b9aca.
As you can see, the functionality is pretty simple, as the actual preview functionality will reside in the application consuming the API. The only thing that Squidex needs to do is to tell the consuming application what specific content that the user wishes to preview.
If needed I could probably whip up a pull request for this. But it would probably take until after the new year before I would have time to do that.
Best regards, Niklas
the API also allows to retrieve unpublished content with the X-Unpublished header. What I did for me website was introducing a “secret” query parameter. So whenever I added “?SUPERSECRET” to the url I add this header to my requests and also see unpublished content.
Of course the preview urls are more convenient for content editors, I think contentful has them.
Sebastian
Yes, the X-Unpublished header is something that the consuming application would have to implement in it’s preview functionality, as long as it can get a reference of what content to preview.
I concur with Niklas, it would be a nice addition, even for a headless CMS.
In order to keep flexibility and the headless philosophy, the preview should be a collection of named urls with configurable routes since, in our use case, a content item could have multiple views/endpoints/urls, e.g. : web, mobile app, api, etc…
It could be implemented as a preview button with a caret + dropdown and a named list (web, mobile app, and so on)
Regards,
Julien
Thanks, it sounds very useful to have multiple preview urls. Should be easy to implement the next 2 weeks.
as promised and very close to the scheduled date: https://docs.squidex.io/guides/09-preview
Looks awesome. Exactly what I was looking for. Super job as always!
