My first observation is that the package hasn’t been updated on NPM.
@squidex/squidex - npm (npmjs.com)
This means I’ll need to sideload it somehow. Due to limitations with Vite I won’t be able to use npm link for this task (at least in Windows). I will use this workaround for testing.
cd node_modules
cd "@squidex"
mv squidex squidex-npm
git clone https://github.com/Squidex/sdk-node.git
mv sdk-node squidex
cd squidex
git checkout openapi-generator
git pull
npm run build
I will note that we have 427 build errors being emitted from the TypeScript transpiler. Most are declared unused variable on the function.
Found 427 errors in 203 files.
Errors Files
1 src/generated/models/ActionTypeEnum.ts:43
2 src/generated/models/AddFieldDto.ts:63
2 src/generated/models/AddLanguageDto.ts:43
2 src/generated/models/AddRoleDto.ts:43
2 src/generated/models/AddWorkflowDto.ts:43
1 src/generated/models/AlgoliaRuleActionDto.ts:90
3 src/generated/models/AllContentsByPostDto.ts:70
3 src/generated/models/AnnotateAssetDto.ts:58
2 src/generated/models/AppDto.ts:138
2 src/generated/models/AppLanguageDto.ts:85
3 src/generated/models/AppLanguagesDto.ts:63
4 src/generated/models/AppSettingsDto.ts:97
1 src/generated/models/ArrayCalculatedDefaultValue.ts:42
2 src/generated/models/ArrayFieldPropertiesDto.ts:67
2 src/generated/models/AssetChangedRuleTriggerDto.ts:41
2 src/generated/models/AssetDto.ts:229
2 src/generated/models/AssetFolderDto.ts:78
1 src/generated/models/AssetFolderScope.ts:43
4 src/generated/models/AssetFoldersDto.ts:77
2 src/generated/models/AssetMeta.ts:43
1 src/generated/models/AssetPreviewMode.ts:43
2 src/generated/models/AssetScriptsDto.ts:99
3 src/generated/models/AssetsDto.ts:70
2 src/generated/models/AssetsFieldPropertiesDto.ts:177
1 src/generated/models/AssetType.ts:44
2 src/generated/models/AssignContributorDto.ts:55
2 src/generated/models/AuthSchemeDto.ts:77
2 src/generated/models/AuthSchemeResponseDto.ts:62
3 src/generated/models/AuthSchemeValueDto.ts:41
1 src/generated/models/AzureQueueRuleActionDto.ts:75
2 src/generated/models/BackupJobDto.ts:99
3 src/generated/models/BackupJobsDto.ts:63
1 src/generated/models/BooleanFieldEditor.ts:42
2 src/generated/models/BooleanFieldPropertiesDto.ts:67
2 src/generated/models/BulkResultDto.ts:69
4 src/generated/models/BulkUpdateAssetsDto.ts:59
3 src/generated/models/BulkUpdateAssetsJobDto.ts:97
1 src/generated/models/BulkUpdateAssetType.ts:43
3 src/generated/models/BulkUpdateContentsDto.ts:94
3 src/generated/models/BulkUpdateContentsJobDto.ts:115
1 src/generated/models/BulkUpdateContentType.ts:48
2 src/generated/models/CallsUsageDtoDto.ts:106
2 src/generated/models/CallsUsagePerDateDto.ts:64
3 src/generated/models/ChangeCategoryDto.ts:34
2 src/generated/models/ChangePlanDto.ts:43
2 src/generated/models/ChangeStatusDto.ts:55
2 src/generated/models/ClientDto.ts:98
3 src/generated/models/ClientsDto.ts:63
1 src/generated/models/CommentRuleActionDto.ts:67
2 src/generated/models/CommentRuleTriggerDto.ts:41
2 src/generated/models/ComponentFieldPropertiesDto.ts:41
2 src/generated/models/ComponentsFieldPropertiesDto.ts:73
4 src/generated/models/ConfigureFieldRulesDto.ts:41
3 src/generated/models/ConfigureUIFieldsDto.ts:40
3 src/generated/models/ContentChangedRuleTriggerDto.ts:80
3 src/generated/models/ContentDto.ts:187
4 src/generated/models/ContentsDto.ts:83
2 src/generated/models/ContributorDto.ts:77
3 src/generated/models/ContributorsDto.ts:82
2 src/generated/models/ContributorsMetadata.ts:43
2 src/generated/models/CreateAppDto.ts:49
2 src/generated/models/CreateAssetFolderDto.ts:49
2 src/generated/models/CreateClientDto.ts:43
1 src/generated/models/CreateContentRuleActionDto.ts:84
2 src/generated/models/CreateRuleDto.ts:63
4 src/generated/models/CreateSchemaDto.ts:143
2 src/generated/models/CreateTeamDto.ts:43
2 src/generated/models/CreateUserDto.ts:64
2 src/generated/models/CurrentStorageDto.ts:50
1 src/generated/models/DateTimeCalculatedDefaultValue.ts:42
1 src/generated/models/DateTimeFieldEditor.ts:42
2 src/generated/models/DateTimeFieldPropertiesDto.ts:91
1 src/generated/models/DiscourseRuleActionDto.ts:105
2 src/generated/models/EditorDto.ts:50
1 src/generated/models/ElasticSearchRuleActionDto.ts:96
1 src/generated/models/EmailRuleActionDto.ts:116
2 src/generated/models/ErrorDto.ts:74
2 src/generated/models/EventConsumerDto.ts:90
3 src/generated/models/EventConsumersDto.ts:63
1 src/generated/models/FastlyRuleActionDto.ts:68
2 src/generated/models/FeatureDto.ts:50
3 src/generated/models/FeaturesDto.ts:57
3 src/generated/models/FieldDto.ts:117
1 src/generated/models/FieldRuleAction.ts:43
2 src/generated/models/FieldRuleDto.ts:65
1 src/generated/models/GeolocationFieldEditor.ts:41
2 src/generated/models/GeolocationFieldPropertiesDto.ts:49
2 src/generated/models/HistoryEventDto.ts:78
1 src/generated/models/ImageFormat.ts:48
2 src/generated/models/ImportContentsDto.ts:62
3 src/generated/models/JobDto.ts:126
2 src/generated/models/JobLogMessageDto.ts:50
3 src/generated/models/JobsDto.ts:63
1 src/generated/models/JobStatus.ts:45
2 src/generated/models/JsonFieldPropertiesDto.ts:41
2 src/generated/models/LanguageDto.ts:57
3 src/generated/models/LogDownloadDto.ts:34
3 src/generated/models/ManualRuleTriggerDto.ts:35
1 src/generated/models/MediumRuleActionDto.ts:105
3 src/generated/models/MoveAssetDto.ts:34
3 src/generated/models/MoveAssetFolderDto.ts:34
2 src/generated/models/NestedFieldDto.ts:98
1 src/generated/models/NotificationRuleActionDto.ts:82
1 src/generated/models/NumberFieldEditor.ts:44
2 src/generated/models/NumberFieldPropertiesDto.ts:91
1 src/generated/models/OpenSearchRuleActionDto.ts:96
2 src/generated/models/PatternDto.ts:56
3 src/generated/models/PlanChangedDto.ts:34
2 src/generated/models/PlanDto.ts:109
3 src/generated/models/PlansDto.ts:95
1 src/generated/models/PlansLockedReason.ts:44
1 src/generated/models/PrerenderRuleActionDto.ts:68
3 src/generated/models/QueryDto.ts:52
3 src/generated/models/QueryJsonDto.ts:89
1 src/generated/models/ReferencesFieldEditor.ts:46
2 src/generated/models/ReferencesFieldPropertiesDto.ts:103
2 src/generated/models/ReferralInfo.ts:57
2 src/generated/models/RenameAssetFolderDto.ts:43
2 src/generated/models/RenameTagDto.ts:43
2 src/generated/models/ReorderFieldsDto.ts:43
1 src/generated/models/ResizeMode.ts:47
2 src/generated/models/Resource.ts:50
2 src/generated/models/ResourceLink.ts:56
2 src/generated/models/ResourcesDto.ts:50
2 src/generated/models/RestoreJobDto.ts:79
2 src/generated/models/RestoreRequestDto.ts:49
2 src/generated/models/RichTextFieldPropertiesDto.ts:89
2 src/generated/models/RoleDto.ts:92
3 src/generated/models/RolesDto.ts:63
2 src/generated/models/RuleDto.ts:152
3 src/generated/models/RuleElementDto.ts:88
2 src/generated/models/RuleElementPropertyDto.ts:92
2 src/generated/models/RuleEventDto.ts:125
3 src/generated/models/RuleEventsDto.ts:70
1 src/generated/models/RuleFieldEditor.ts:49
1 src/generated/models/RuleJobResult.ts:45
1 src/generated/models/RuleResult.ts:44
3 src/generated/models/RulesDto.ts:69
2 src/generated/models/ScheduleJobDto.ts:71
2 src/generated/models/SchemaChangedRuleTriggerDto.ts:41
2 src/generated/models/SchemaCondition.ts:49
4 src/generated/models/SchemaDto.ts:208
2 src/generated/models/SchemaPropertiesDto.ts:91
3 src/generated/models/SchemaScriptsDto.ts:64
3 src/generated/models/SchemasDto.ts:63
1 src/generated/models/SchemaType.ts:43
1 src/generated/models/ScriptRuleActionDto.ts:60
2 src/generated/models/SearchResultDto.ts:78
1 src/generated/models/SearchResultType.ts:46
1 src/generated/models/SignalRRuleActionDto.ts:105
2 src/generated/models/SimulatedRuleEventDto.ts:102
3 src/generated/models/SimulatedRuleEventsDto.ts:70
1 src/generated/models/SkipReason.ts:51
1 src/generated/models/SlackRuleActionDto.ts:68
2 src/generated/models/SortNode.ts:59
1 src/generated/models/SortOrder.ts:42
2 src/generated/models/StatusInfoDto.ts:50
2 src/generated/models/StorageUsagePerDateDto.ts:57
1 src/generated/models/StringContentType.ts:43
1 src/generated/models/StringFieldEditor.ts:50
2 src/generated/models/StringFieldPropertiesDto.ts:169
5 src/generated/models/SynchronizeSchemaDto.ts:119
1 src/generated/models/TagsFieldEditor.ts:43
2 src/generated/models/TagsFieldPropertiesDto.ts:85
2 src/generated/models/TeamDto.ts:91
2 src/generated/models/TemplateDetailsDto.ts:57
2 src/generated/models/TemplateDto.ts:78
3 src/generated/models/TemplatesDto.ts:63
3 src/generated/models/TransferToTeamDto.ts:34
2 src/generated/models/TranslateDto.ts:56
2 src/generated/models/TranslationDto.ts:65
1 src/generated/models/TranslationStatus.ts:46
1 src/generated/models/TweetRuleActionDto.ts:76
1 src/generated/models/TypesenseRuleActionDto.ts:90
1 src/generated/models/UIFieldEditor.ts:41
2 src/generated/models/UIFieldPropertiesDto.ts:49
3 src/generated/models/UpdateAppDto.ts:40
4 src/generated/models/UpdateAppSettingsDto.ts:75
3 src/generated/models/UpdateAssetScriptsDto.ts:70
3 src/generated/models/UpdateClientDto.ts:58
2 src/generated/models/UpdateFieldDto.ts:50
3 src/generated/models/UpdateLanguageDto.ts:46
3 src/generated/models/UpdateProfileDto.ts:34
2 src/generated/models/UpdateRoleDto.ts:49
3 src/generated/models/UpdateRuleDto.ts:65
3 src/generated/models/UpdateSchemaDto.ts:70
2 src/generated/models/UpdateSettingDto.ts:43
2 src/generated/models/UpdateTeamDto.ts:43
2 src/generated/models/UpdateUserDto.ts:63
2 src/generated/models/UpdateWorkflowDto.ts:69
5 src/generated/models/UpsertSchemaDto.ts:107
3 src/generated/models/UpsertSchemaFieldDto.ts:93
2 src/generated/models/UpsertSchemaNestedFieldDto.ts:75
1 src/generated/models/UsageRuleTriggerDto.ts:67
2 src/generated/models/UserDto.ts:85
2 src/generated/models/UserProperty.ts:50
3 src/generated/models/UsersDto.ts:70
1 src/generated/models/WebhookMethod.ts:45
1 src/generated/models/WebhookRuleActionDto.ts:104
2 src/generated/models/WorkflowDto.ts:89
3 src/generated/models/WorkflowsDto.ts:70
3 src/generated/models/WorkflowStepDto.ts:71
3 src/generated/models/WorkflowTransitionDto.ts:40
Files: 452
Lines of Library: 39157
Lines of Definitions: 129518
Lines of TypeScript: 33489
Lines of JavaScript: 0
Lines of JSON: 0
Lines of Other: 0
Identifiers: 180509
Symbols: 107323
Types: 8853
Instantiations: 4374
Memory used: 341663K
Assignability cache size: 2390
Identity cache size: 158
Subtype cache size: 88
Strict subtype cache size: 120
I/O Read time: 0.05s
Parse time: 0.51s
ResolveModule time: 0.06s
ResolveTypeReference time: 0.01s
ResolveLibrary time: 0.01s
Program time: 0.72s
Bind time: 0.34s
Check time: 0.69s
transformTime time: 0.21s
commentTime time: 0.14s
I/O Write time: 0.14s
printTime time: 0.93s
Emit time: 0.93s
Total time: 2.68s
When I run npm run astro build on my project with the release candidate SDK, I’m getting a couple of errors here:
Debugger listening on ws://127.0.0.1:54501/cff097e3-ec4e-4702-91c4-274c4e3f40ca
For help, see: https://nodejs.org/en/docs/inspector
Debugger attached.
> dashersupply@0.2.1 astro
> astro build
Debugger listening on ws://127.0.0.1:54504/c0ede1cc-1f1e-4469-84f1-d3bceb054dc1
Debugger attached.
16:05:53 [WARN] [config] The feature "astro:env getSecret" is experimental and subject to change (used by @astrojs/node).
16:05:53 [vite] Re-optimizing dependencies because lockfile has changed
16:05:53 [types] Generated 101ms
16:05:53 [build] output: "server"
16:05:53 [build] directory: D:\sources\dashersupply\dist\
16:05:53 [build] adapter: @astrojs/node
16:05:53 [build] Collecting build info...
16:05:53 [build] ✓ Completed in 125ms.
16:05:53 [build] Building server entrypoints...
16:05:54 [ERROR] [vite] x Build failed in 411ms
[commonjs--resolver] Failed to resolve entry for package "@squidex/squidex". The package may have incorrect main/module/exports specified in its package.json.
Stack trace:
at packageEntryFailure (file:///D:/sources/dashersupply/node_modules/vite/dist/node/chunks/dep-Cy9twKMn.js:46533:15)
at tryNodeResolve (file:///D:/sources/dashersupply/node_modules/vite/dist/node/chunks/dep-Cy9twKMn.js:46346:16)
at Object.handler (file:///D:/sources/dashersupply/node_modules/vite/dist/node/chunks/dep-Cy9twKMn.js:65535:15)
at async PluginDriver.hookFirstAndGetPlugin (file:///D:/sources/dashersupply/node_modules/rollup/dist/es/shared/node-entry.js:19813:28)
at async ModuleLoader.resolveId (file:///D:/sources/dashersupply/node_modules/rollup/dist/es/shared/node-entry.js:18890:15)
Waiting for the debugger to disconnect...
Upon inspection the package.json file shows the entry point and the types are at ‘./index.js’ and ‘./index.d.ts’, respectively, but those files are not present. Instead they should be at ‘./dist/index.js’ and ‘./dist/index.d.ts’ instead. I’ve patched the package.json for the SDK, and then try again.
Re-run npm run-script astro build after patching node_modules/@squidex/squidex/package.json with success.
Looks like the new interface supports Blobs, so I think this new SDK will resolve this issue.
The new upload function should work like this with the new SDK.
export async function uploadDownloadedImageToSquidexAsAsset(downloadUrl: string, assetFolderId: string) {
let filename = downloadUrl.substring(downloadUrl.lastIndexOf('/')+1);
let response = await axios.get(downloadUrl, { timeout: TIMEOUT_IN_SECONDS * 1000, responseType: 'blob' });
let assetDto = await client.assets.postAsset({ file: response.data, fileName: filename });
assetDto = await client.assets.putAsset({ id: assetDto.id, annotateAssetDto: { metadata: { ...assetDto.metadata, 'amazon-url': downloadUrl }, tags: ['amazon', 'product'] } })
assetDto = await client.assets.putAssetParent({ id: assetDto.id, moveAssetDto: { parentId: assetFolderId } });
return assetDto;
Here is a list of all of the things as an SDK consumer I had to change in my project, aside from the package.json patch, as a result of the migration.
Migrated to release candidate Squidex SDK · 77b83f51dd - dashersupply - Gitea: Git with a cup of tea (daball.me)
I will note that the new SDK also fails at getReferences(), which you were saying needed a patch in .NET codebase for Squidex.
let redirectReferencesDto = await client.contents.getReferences({ schema: SCHEMAS.REDIRECTS, id: redirectDto.items[0].id });
console.log("redirectReferencesDto:", redirectReferencesDto);
I didn’t figure out which version I need to set my Docker to get the patch for that on the .NET side.
TypeError: Cannot read properties of undefined (reading 'map')
at ContentsDtoFromJSONTyped (...\node_modules\@squidex\squidex\dist\generated\models\ContentsDto.js:49:39)
at ContentsDtoFromJSON (...\node_modules\@squidex\squidex\dist\generated\models\ContentsDto.js:39:12)
at JSONApiResponse.transformer (...\node_modules\@squidex\squidex\dist\generated\apis\ContentsApi.js:532:105)
at JSONApiResponse.<anonymous> (...\node_modules\@squidex\squidex\dist\generated\runtime.js:298:25)
at Generator.next (<anonymous>)
at fulfilled (...\node_modules\@squidex\squidex\dist\generated\runtime.js:18:58)
at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
Fine work, Sebastian. I’ll let you know if I have any trouble, but I suspect this SDK will work even better than the fern SDK. I’m getting better response times.
