Requested by a user.
Hi Sebastian, this sounds pretty useful. Am I right in saying it will mean filtering will provide all the âAllowed Valuesâ instead of requiring you to type in the value manually?
For example we have quite a basic A-Z category setup in one of our fields:
And at the moment we need to type in the character we want to search for:
Obviously for this example typing in âAâ isnât much of a hassle but if allowed values are longer like âAppleâ, âOrangeâ, âBreadâ etc then having a dropdown will make it much easier and weâll aim to get it deployed and tested sooner rather than later.
Also in a separate question does invalidate some of the Validation options for string fields like Min and Max Length?
Best regards,
Paul
No, it will only mean that in GraphQL an enum is generated for this field to have more type safety in the clients / code.
But your feature request makes sense. You can create a separate feature request for that and it should be relatively straight forward to implement this.
