Nan
                    November 6, 2024,  2:33pm
                  1
Troubleshooting and Support | Squidex . I understand that my support request might get deleted if I do not follow the guideline.
I’m tried to fetch bearer token but scripting return 400 error
Fetch bearer token.
const url = `https://some.service.inc/identity-server/connect/token`;
const headers = {
    'Content-Type': `application/x-www-form-urlencoded`
const body = JSON.stringify({
    grant_type: 'client_credentials',
    client_id: 'clientId',
    client_secret: 'clientSecret',
    scope: 'squidex-api'
postJSON(url, body, (data) => {
    var b = 2
}, headers);
App Name: test-app
Version: latest
              Which error do you get?  Is there a concrete message?
              I see it now. PostJSON expects a JSON request body and response body. There is no solution to make these kind of queries at the moment.
                Nan
                    November 7, 2024, 10:53am
                  5
              So to use getJson method to get some data I should manually update every month bearer token?
              Unfortunately yes, perhaps I can migrate fetch to the scripting engine to give more flexibility.
                Nan
                    November 7, 2024,  6:20pm
                  7
              It’s would be amazing, could you please do that?
              I have added a simple workaround for now:
var url = 'http://squidex.io';
var body = { key: 42 };
postJSON(url, body, function(actual) {
    complete(actual);
    'Content-Type': 'application/x-www-form-urlencoded'
When the header is set, the body is sent as url encoded string.
                Nan
                    November 10, 2024,  8:30pm
                  9
              I tried the next one request to get bearer token so that failed
var url = 'https://dev-admin.squidexsite.com/identity-server/connect/token';
var body = { grant_type: 'client_credentials', client_id: '{client id}', client_secret: '{token}', scope: 'squidex-api'};
    complete(actual);
Could you please try request bearer token on your env?
              Sorry, it was not merged nor deployed.
                Nan
                    November 11, 2024,  1:00pm
                  11
              Np, I saw you merged changes, will you create new release?
              Not immediately, but every commit goes to a few thousand unit tests, api tests and e2e tests. There is no release test or something like that anyway.
                Nan
                    November 11, 2024,  2:12pm
                  13
              I pinned and try latest build from master.
Code:
const url = 'https://dev-admin.test.com/identity-server/connect/token';
const headers = {
const body = {
    client_id: 'app-management:instruction-verifycation',
    client_secret: 'xbszwjqigp6qwtynkh5oy5tepdrakw4shyu7xojd4ekx',
    throw `Duplicate reference detected: ${JSON.stringify(data)} cooking instruction with SKU already exist.`;
}, headers, true);
So the same error:{"statusCode":400,"headers":{"Content-Length":"175","Content-Type":"application/json; charset=UTF-8","Expires":"Thu, 01 Jan 1970 00:00:00 GMT","Date":"Mon, 11 Nov 2024 14:09:20 GMT","Server":"Kestrel","Cache-Control":"no-store","Pragma":"no-cache"},"body":"{\n "error": "invalid_request",\n "error_description": "The specified 'Content-Type' header is invalid.",\n "error_uri": "[https://documentation.openiddict.com/errors/ID2082\"\n}"} ](https://documentation.openiddict.com/errors/ID2082/%22/n%7D%22%7D)
              Looks correct. I will test it again and inform you later.
              I have tested it again and it works fine for me. Are you sure, you have the latest version.
                Nan
                    November 11, 2024,  5:35pm
                  16
              I used image with tag dev-8131
              That’s the correct one. For me it works. Not sure how to reproduce it.
                Nan
                    November 11, 2024,  6:31pm
                  18
              May we quick call I can show it to you?
Btw do you use ignoreError as true and check data from callback?
                Nan
                    November 11, 2024,  6:44pm
                  20
              Could you please show me your script fully without editing
