Hello Sebastian,
We are using Squidex to edit content in many languages. The screenshot attached should provide a clear example.
Is it possible to show the same field in multiple languages one underneath the other instead of using the drop down menu?
Not yet, I think for most editors it would also not make a lot of sense. Perhaps a setting would work.
Is it something that can be requested as a feature?
Everything can be requested but not everything will be implemented
Do you think that it should be an button in the UI or a general setting?
An option would be adding this setting when creating the field. When checking the ‘Localizable’ tick box, an additional option is shown, for example ‘Unfold languages’. I presume setting it at schema level is of course easier when rendering the UI for content management.
Another (more preferred) option is to have fold/unfold button next to localizable fields to open them all one after the other.
I will publish this feature tomorrow.
Hello Sebastian,
Apologies for the delay. Thanks for the feature implementation.
I wish you a Happy New Year!
