Tags cannot be modified or edited in the nested asset – unlike in the asset area. Asset area works perfectly when adding additional tags.
Add a nested schema with an asset and modify tags.
The assets in the content editor are in readonly mode. It is by design to prevent the synchronization issues when you reference the same asset multiple times.
I will create a feature request out of it.
Implemented and deployed.
