[IMPLEMENTED] Delete assets permanently
Hello,
By mistake, I have uploaded so many assets (112K) with batch processing using client library and it increased asset size to 20GB.
And when I came to know about this mess, I deleted all those images with client library with hoping it will free up my space. But when I deleted all unwanted assets, still my asset size was showing the same size(20GB).
FYI : We have Self hosted Solution.
Please let me know what I need to do to free up my space.
Thanks,
Creative Mind
it is by design. Storage is so cheap and available with S3 and so on that I actually do not delete assets.
Hello,
How would I find and delete the files manually then (Docker setup)?
You should never ever store the files in Docker. Please mount them: https://github.com/Squidex/squidex-docker/blob/master/standalone/docker-compose.yml#L33
It is mounted it to a persistent volume. Still what’s the best way to identify the non-referenced files on the volume?
The best approach is just to wait a few hours because I have already a PR in the pipeline :wink:
It has been implemented with dev-5740 flag (which might not be built yet, when you read this answer).
Just turn the setting on with https://github.com/Squidex/squidex/blob/master/backend/src/Squidex/appsettings.json#L310
ASSETS__DELTEPERMANENT=true
Will also work for your already deleted assets.
BUILD STATUS: https://build.squidex.io/Squidex/squidex/5740
Okay, Thank you so much for quick response!
