[IMPLEMENTED] Custom Editor (Schema, Schema Fields)
I need a custom editor on the content side. I need to put a dropdown object and display schemas inside it. Then I want to show the fields of the selected schema in another dropdown object.
Schema Selected
I need both the id of the schema and the name of the selected field in the background.
Its data model can be json or a string separated by a special expression.
Can you help me for this?
Thank you.
You mean a sidebar plugin? You cannot edit content values there right now.
What do you mean with the “selected field”?
No,
i want to talk about Custom Editor (Editor Url)
Unfortunately, the selected field name and the schema id are not available right now. I can change that.
I need the id of the selected schema in the schema list and the list of fields and the name of the selected field. I need to design a custom editor(Editor Url) for this. I would be very happy if you could make these possible.
Sure, I will have a look.
How can I integrate this?
The schema is available in the context of the editor. YOu can call field.getContext().
There is also a sample editor just to view the context: https://github.com/Squidex/squidex/tree/master/backend/src/Squidex/wwwroot/scripts
I have just seen that the production build of the master has an issue with angular. Going to fix that today.
did you finish all your fixes? Or would you suggest I wait?
Also, I still don’t understand how to use it.
can you explain a little more?
Thank you
The editor can subscribe to an init callback that is invoked once. This callback has an argument called “context”, which contains all information like user-credentials, app name and so on and also the schema with the fields now.
You can use the following editor as an example to have a look to the context: https://github.com/Squidex/squidex/blob/master/backend/src/Squidex/wwwroot/scripts/editor-context.html
It is also described here: https://docs.squidex.io/02-documentation/developer-guides/editors#context
