There is a field type - Tags.
For adding a new value in UI (cloud.squidex.io) it’s required to type the tag (or copy) value and input a comma.
However, when I need to duplicate the same values/tags in another content item - I did not find a possibility for copying tags. I had to do it manually.
In case I copy a string with commas (e.g. ‘tag1, tag2’) and add a comma after - the whole string (including the commas) will be treated as a tag (the tag will be - ‘tag1, tag2’ instead of ‘tag1’, ‘tag2’).
Is there such possibility?
