[IMPLEMENTED] Bulk updating of images
I have about 400 existing images that I need to update. The updated files have exactly the same names as the ones already on Squidex. I know that I can drag/drop the files on-by-one to update them, but is there any way to do them all at once?
I suppose that if I delete the existing images all references to them (in schema records) will be removed, so that’s not a good approach.
Thanks for your help.
-Barton
You have to write your own tool using the API to implement that. Perhaps I can provide a sample next week or add a feature to the CLI.
Thanks, Sebastian. It would be wonderful if you could provide a sample or enhance the CLI. I’m sure that other users would also benefit from this functionality.
-Barton
I have updated the existing CLI command to also make updates: https://github.com/Squidex/squidex-samples/blob/master/cli/Squidex.CLI/Squidex.CLI/Commands/App_Assets.cs#L39
This command allows you to upload a full folder hierarchy to Squidex.
This sounds great Sebastian! Thanks! I’ll try it out soon.
-Barton
Have you had a chance to test it?
Hi Sebastian. I just tried it, but got an error. Here’s the command I used:
.\cli\sq.exe assets import .\test_som1_images -t images
The folder, “.\test_som1_images” is a folder on my local drive with the images I want to update.
The images are in an “images” folder on Squidex, which is why I used the, “-t images” parameter.
The error I received is:
ERROR: HTTP Response:
{"traceId":"00-fc6a361d787f0745ea735ae11d07cce4-c252bc42ec53b9e3-01","type":"https://tools.ietf.org/html/rfc7231#section-6.5.4","statusCode":404}
Squidex.ClientLibrary.Management.SquidexManagementException: App not found.
Status: 404
Response:
   at Squidex.ClientLibrary.Management.AssetsClient.GetAssetFoldersAsync(String app, String parentId, Nullable`1 scope, CancellationToken cancellationToken)
   at Squidex.CLI.Commands.Implementation.Sync.Assets.FolderTree.QueryAsync(String id, Boolean needsChildren)
   at Squidex.CLI.Commands.Implementation.Sync.Assets.FolderTree.GetIdAsync(String path)
   at Squidex.CLI.Commands.App.Assets.List(ImportArguments arguments)
   at CommandDotNet.Execution.InvocationResultExtensions.GetResultCodeAsync(Object value)
   at CommandDotNet.AppRunner.HandleException(Exception ex, IConsole console, CommandContext commandContext)
   at CommandDotNet.AppRunner.Run(String[] args)
   at Squidex.CLI.Program.Main(String[] args)
Perhaps I’m using the command incorrectly. (I did select my app configuration before executing it.)
Let me know if I should create an issue in Github.
Do you have an client with proper permissions? And have you set the url properly when registering the app in the CLI?
There was a problem with my config. Once fixed the import command worked perfectly!
Thank you for your amazing responsiveness!
-Barton
I don’t know if you have realized it, but it will also keep your folder structure.
That’s good to know.
I’m not exaggerating when I say that Squidex is the most elegantly designed platform that I’ve used in my 45+ years of working with technology. I recommend it whenever I get the chance!
Hi Sebastian. One other note on this. In further testing I accidentally included an image file that did not already exist in the app. When the file was encountered the following error was triggered:
Uploading: numbers-1.png
Error: System.NullReferenceException: Object reference not set to an instance of an object.
ERROR: System.NullReferenceException: Object reference not set to an instance of an object.
   at Squidex.CLI.Commands.Implementation.LogExtensions.HandleException(Exception ex, Action`1 error)
Perhaps you want to add a flag to allow import when the image does not already exist? Or make that the default action?
This is a bug, I will have a look.
I cannot reproduce it.
Have you tried it with the “-t” option? That’s how I used the command, in order to target a specific asset folder.
No, I will have a look.
I can still not reproduce it. Perhaps I have just fixed it. You can also send me your folder and exact command if you want.
I installed the latest CLI (v7.16.0) and now it works! Thanks very much!
