Hello,
We were using a References field to link to a single item and had checked ‘Resolve references’ so that the name was shown in various places (such as Contents view) instead of ‘1 Reference’, however we are now using a Component field instead and there is no equivalent option so it just says ‘{ Component }’:
Would it be possible to automatically show the Label (or Name if no Label is provided) of the component schema being used in the Component type field?
If that is possible an extension of this would be to add an option similar to ‘Resolve references’ for the Components type field that takes effect when only one Component has been added.
Best regards,
Paul
