Hello
we would like it if the numbers gave the possibility to set an auto increment. We have now had the problem a couple of times that we had to create this through the code.
Greetings
Andreas
Hello
Greetings
Andreas
I am not sure if I will create something for fields directly, but perhaps a counter functionality for scripts.
I added a script counter (per app)
usage
ctx.data.number.iv = incrementCounter('abc2');
replace();
Will be deployed soon
Hello
thatâs cool
Works flawlessly. Thanks for your work.
And sorry for the long reaction time ⌠Corona sends its regards.
Greetings Andreas
I get the following error:
Failed to execute script with javascript error: Object has no method âincrementCounterâ.
* Object has no method 'incrementCounter'.
Can you pinpoint me to what am I doing wrong?
Which version are you using?
Thanks for the fast response.
Cloud
Okay, I will check if it deployed. I am not sure to be honest. Usually I update the feature requests after deployments. Can you also post your script?
Sure itâs pretty straight forward:
ctx.data.barcodeSuffix.iv = incrementCounter('tru-dev');
replace();
Sorry, notâŚI think it is just not deployed yet, but I will check it again today and then deploy it.
Hi, I have deployed it.
