- [X] Used code blocks with ``` to format my code examples like JSON or logs properly.
- [X] Bug report
Create a schema with a regular string field and an array field with a string nested field, both set as localizable. Create a new item in this schema and fill out the string field and add one item to the array under English, and publish.
The data will contain “null” for any other optional languages for the regular string field, but the array field will default as [] instead of null and have no language fallback in the API unless you manually clear the field out for every language or set it to null.
Array fields should default to “null” instead of an empty array for optional languages to enable API language fallback.
Schema:
"previewUrls": {},
"properties": {
"validateOnPublish": false
"scripts": {},
"isPublished": true,
"fieldRules": [],
"fieldsInLists": [],
"fieldsInReferences": [],
"fields": [
"name": "localstring",
"properties": {
"isRequired": false,
"isRequiredOnPublish": false,
"isHalfWidth": false,
"fieldType": "String",
"createEnum": false,
"editor": "Input",
"inlineEditable": false,
"isEmbeddable": false,
"isUnique": false,
"contentType": "Unspecified",
"label": "Local String"
"isLocked": false,
"isHidden": false,
"isDisabled": false,
"partitioning": "language"
"name": "localarray",
"properties": {
"fieldType": "Array",
"label": "Local Array"
"isLocked": false,
"isHidden": false,
"partitioning": "language",
"nested": [
"name": "label",
"properties": {
"editor": "Input",
"isUnique": false,
"isLocked": false,
"isHidden": false,
"isDisabled": false
"type": "Default"
Example item I created
"localstring": {
"en": "Test",
"en-AW": null,
"en-BM": null,
"en-HT": null,
"en-JM": null
"localarray": {
"en": [
"label": "test"
"en-AW": [],
"en-BM": [],
"en-HT": [],
"en-JM": []
- [X] Self hosted with docker
- [X] Chrome (desktop)
… But yes, I will probably work on that next week.
