Hello,
We’ve had feedback that we should not show the “Custom ID” field to our users:
As they always want to rely on generated IDs, this field (although it is very subtle) could cause a small bit of confusion and takes a little chunk out of the available screen space (especially as it follows you while you scroll).
Edit: Forgot to say that for us we could happily disable this at the App level as we don’t have any users that we want using this functionality, however having an option at schema level would probably be more flexible.
I feel like I have seen this mentioned before but I cannot find it to see what your feelings were on this. Not a major issue as it shouldn’t hurt if users do make use of this functionality and like I said it is quite a subtle field atm so some users didn’t even notice it was there!
Best regards,
Paul
