Every couple of days, I’m getting an orleans error saying it can’t open the port it needs to. This has now happened three times (over 6 days). I’ve changed the port on the appsettings to 21111 to see if that helps. I’m assuming another asp.net application tries to use that port dynamically and then it fails when orleans tries to grab it.
Any thoughts?
In the event log, the first error I get is:
Application: w3wp.exe
CoreCLR Version: 4.700.19.60701
.NET Core Version: 3.1.1
Description: The process was terminated due to an unhandled exception.
Exception Info: System.OperationCanceledException: The operation was canceled.
at System.Threading.CancellationToken.ThrowOperationCanceledException()
at Microsoft.Extensions.Hosting.Internal.Host.StopAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.WaitForShutdownAsync(IHost host, CancellationToken token)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token)
at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host)
at Squidex.Program.Main(String[] args) in /src/src/Squidex/Program.cs:line 23
and then
Exception Info: Microsoft.AspNetCore.Connections.AddressInUseException: Only one usage of each socket address (protocol/network address/port) is normally permitted.
---> System.Net.Sockets.SocketException (10048): Only one usage of each socket address (protocol/network address/port) is normally permitted.
at System.Net.Sockets.Socket.UpdateStatusAfterSocketErrorAndThrowException(SocketError error, String callerName)
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at Orleans.Networking.Shared.SocketConnectionListener.Bind()
at Orleans.Networking.Shared.SocketConnectionListenerFactory.BindAsync(EndPoint endpoint, CancellationToken cancellationToken)
at Orleans.Runtime.Messaging.ConnectionListener.BindAsync(CancellationToken cancellationToken)
at Orleans.Runtime.Messaging.SiloConnectionListener.OnRuntimeInitializeStart(CancellationToken cancellationToken)
at Orleans.Runtime.SiloLifecycleSubject.MonitoredObserver.OnStart(CancellationToken ct)
at Orleans.LifecycleSubject.<OnStart>g__CallOnStart|7_0(Int32 stage, OrderedObserver observer, CancellationToken cancellationToken)
at Orleans.LifecycleSubject.OnStart(CancellationToken ct)
at Orleans.Runtime.Scheduler.AsyncClosureWorkItem.Execute()
at Orleans.Runtime.Silo.StartAsync(CancellationToken cancellationToken)
at Orleans.Hosting.SiloWrapper.StartAsync(CancellationToken cancellationToken)
at Orleans.Hosting.SiloHostedService.StartAsync(CancellationToken cancellationToken)
at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken)
