- [X] Self hosted with IIS
Version: 4.2
Hello Sebastian
I wanted to use the Identity app in version 4.2. I downloaded the squidex-identity and created the Identity app in Squidex. All settings made.
The registration works without problems.
However, the registration does not work afterwards. The user is logged on, but after that the login is gone.
Here are two screenshots.
What am I doing wrong?
Login:
Redirect to Index:
The old versions worked. Only those with Dotnet Core 3.1 don’t work for me.
Greetings
Andreas
