I would like to know if you have a plan for more than 1500k api calls?
Not yet, but it is easy to add another plan.
So, if i need more than 1500K api calls i can jus add another “business plan” in order to double up the calls? Is that so?
And how it can be done, actually?
I mean from our side plans are just configuration values so I can easily a bigger plan.
You could also consider creating multiple apps. This would work as a protection so that you can easily protect your more important content from less important content.
