I’m preparing for an upgrade from Squidex version 5.9.0 to the latest stable Squidex version as of today which is 7.8.2.
You mentioned “single instance” in your latest reply of this question:
Yes, the changelog mentions long running migrations, that run automatically, but cause a temporary downtime. If you have a single instance there is not that much to do. Just upgrade the version in docker engine or kubernetes.
I was just wondering what exactly classifies as a “single instance”?
In my PROD Kubernetes setup I have the following resources for Squidex:
MongoDB:
apiVersion: mongodbcommunity.mongodb.com/v1
kind: MongoDBCommunity
metadata:
namespace: mongodb
spec:
members: 3
type: ReplicaSet
version: "4.2.6"
security:
authentication:
modes: ["SCRAM"]
users:
- name: REDACTED
db: REDACTED
passwordSecretRef:
roles:
- name: REDACTED
db: REDACTED
scramCredentialsSecretName: REDACTED
statefulSet:
spec:
template:
spec:
containers:
- name: mongod
resources:
requests:
cpu: 50m
memory: 1Gi
limits:
cpu: 2000m
memory: 4Gi
- name: mongodb-agent
resources:
requests:
cpu: 50m
memory: 1Gi
limits:
cpu: 2000m
memory: 2Gi
Squidex:
apiVersion: apps/v1
kind: Deployment
metadata:
namespace: REDACTED
spec:
revisionHistoryLimit: 2
selector:
matchLabels:
template:
metadata:
labels:
spec:
containers:
- name: squidex
image: squidex/squidex:5.9.0
resources:
requests:
cpu: 40m
memory: 700Mi
limits:
cpu: 1000m
memory: 1Gi
env:
- name: URLS__BASEURL
value: "REDACTED"
- name: ASSETSTORE__TYPE
value: MongoDb
- name: ASSETSTORE__MONGODB__CONFIGURATION
valueFrom:
secretKeyRef:
key: REDACTED
- name: EVENTSTORE__MONGODB__CONFIGURATION
valueFrom:
secretKeyRef:
key: REDACTED
- name: STORE__MONGODB__CONFIGURATION
valueFrom:
secretKeyRef:
key: REDACTED
- name: IDENTITY__ADMINEMAIL
valueFrom:
secretKeyRef:
key: REDACTED
- name: IDENTITY__ADMINPASSWORD
valueFrom:
secretKeyRef:
key: REDACTED
- name: ASSETS__MAXSIZE
value: "52428800"
- name: LOGGING__LEVEL
value: "Error"
- name: ROBOTS__TEXT
value: "User-agent: *\nAllow: /api/assets/\nDisallow: /"
So as you can see I have 3 replicas for MongoDB. Would this mean I have “three instances” and not a “single instance” like you said?
