- Bug report
- Performance issue
If I send the following JSON object in a bulk (bulkUpdateContents) against the API and use the PATCH method, fields that are set to NULL are not changed. The old value is retained.
In an article from 2021, this topic was discussed once before and a deployment was announced. LINK
The value of a field can be unset with NULL, similar to the UI function unset value.
Send an object via bulkUpdateContents and the PATCH method against the API. The de field contains a value before the request.
en: 'english translation text',
de: null,
es: null,
fr: null,
nl: null,
pl: null,
pt: null
- Self hosted with docker
- Self hosted with IIS
- Cloud version
npm Package Version: 1.2.1
Version: 7.13.0
- Chrome (desktop)
- Chrome (Android)
- Chrome (iOS)
- Firefox
- Safari (desktop)
- Safari (iOS)
- IE
- Edge
