How to serialize items in client library?
  • [ ] Checked the logs and have provided the logs if I found something suspicious there
  • [ ] Bug report
  • [x ] Documentation issue or request
Currently i cant find any documentation on how to serialize an items list in the client library, i am trying with my class
public sealed class FaqData
    public Dictionary<string, string> headline { get; set; }
    public Dictionary<string, string> subheader { get; set; }
    public List<FaqItem> items { get; set; }
public sealed class FaqItem
    public string Title { get; set; }
    public string Text { get; set; }
I looked at Nested Schema translation to c# code
But this doesnt work for some reason when doing it like an array[] type:
    public FaqItem[] items { get; set; }
public class FaqItem
I would like to have a wiki page on the client library explaining how to serialize array items with localization behaviour.
See others for schema.
public SquidexClientManager Manager()
var clientManager = new SquidexClientManager(BaseUrl, Appname, Client_Id, Client_Secret);
return clientManager;
public void GetFaq()
    var clientManager = Manager();
    var faqrepo = clientManager.GetClient<Faq, FaqData>("faq");
    var faqs =  faqrepo.GetAsync().Result;
This will result in an error stating:
One or more errors occurred. (Property must have a invariant language property.)
Can you advise me on how to fix this, or where to read the correct documentation, sorry im still very new to squidex and have searched high and low.
  • [ ] Self hosted with docker
  • [ x] Cloud version
Version: [CLOUD]
  • [x ] Chrome (desktop)
Including json for schema:
“fields”: [
“name”: “headline”,
“properties”: {
“editor”: “Input”,
“fieldType”: “String”
“_links”: {
“update”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/2”,
“method”: “PUT”
“hide”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/2/hide”,
“method”: “PUT”
“disable”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/2/disable”,
“method”: “PUT”
“lock”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/2/lock”,
“method”: “PUT”
“delete”: {
“method”: “DELETE”
“canDelete”: true,
“canDisable”: true,
“canHide”: true,
“canLock”: true,
“canUpdate”: true,
“partitioning”: “language”
“name”: “subheader”,
“properties”: {
“editor”: “Input”,
“_links”: {
“update”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/3”,
“method”: “PUT”
“hide”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/3/hide”,
“method”: “PUT”
“disable”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/3/disable”,
“method”: “PUT”
“lock”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/3/lock”,
“method”: “PUT”
“delete”: {
“method”: “DELETE”
“canDelete”: true,
“canDisable”: true,
“canHide”: true,
“canLock”: true,
“canUpdate”: true,
“name”: “items”,
“properties”: {
“editor”: “Default”,
“fieldType”: “Array”
“_links”: {
“update”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1”,
“method”: “PUT”
“hide”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/hide”,
“method”: “PUT”
“disable”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/disable”,
“method”: “PUT”
“fields/add”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested”,
“method”: “POST”
“fields/order”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/ordering”,
“method”: “PUT”
“lock”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/lock”,
“method”: “PUT”
“delete”: {
“method”: “DELETE”
“canAddField”: true,
“canDelete”: true,
“canDisable”: true,
“canOrderFields”: true,
“canHide”: true,
“canLock”: true,
“canUpdate”: true,
“partitioning”: “language”,
“nested”: [
“name”: “Title”,
“properties”: {
“editor”: “Input”,
“_links”: {
“update”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/4”,
“method”: “PUT”
“hide”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/4/hide”,
“method”: “PUT”
“show”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/4/disable”,
“method”: “PUT”
“lock”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/4/lock”,
“method”: “PUT”
“delete”: {
“method”: “DELETE”
“canDelete”: true,
“canHide”: true,
“canLock”: true,
“canShow”: true,
“canUpdate”: true
“name”: “Text”,
“properties”: {
“editor”: “RichText”,
“_links”: {
“update”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/5”,
“method”: “PUT”
“hide”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/5/hide”,
“method”: “PUT”
“show”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/5/disable”,
“method”: “PUT”
“lock”: {
“href”: “/api/apps/adhub-estate/schemas/faq/fields/1/nested/5/lock”,
“method”: “PUT”
“delete”: {
“method”: “DELETE”
“canDelete”: true,
“canHide”: true,
“canLock”: true,
“canShow”: true,
“canUpdate”: true
“properties”: {}
Hi, the same question has been asked recently: Nested Schema translation to c# code
