How to migrate from 4.5.1 to lastest
  • [ x] Performance issue
Current i use in my production with 4.5.1. Try create new squidex with new version and dump mongo db (old squidex version) and connect. It login ok but not show data from old db
  • [ x] Self hosted with docker
Version: 4.5.1
  • [ ] Chrome (desktop)
Can you help me, how to migrate from 4.5.1 to lastest
If you can you recommend version squidex good with production
Thank you !!!
Usually Squidex should upgrade itself, but I do not have a test for every combination of versions. You could send me a backup of your mongo database (before and after) and I can have a look.
