- [x] Self hosted with docker
Version: 3.15
I’m trying to get GQL Schema from the Squidex using the apollo tool:
yarn apollo service:download --endpoint https://DOMAIN/app/PROJECT/api/graphql --header "Authorization: Bearer TOKEN"
But getting the following error which basically means that there is no GQL Scheme in response:
Error: ServerParseError: Unexpected end of JSON input
How to get the schema from the squidex?
