How to get flat data for content with GraphQL
Hey Squidex Team,
You mention implementing flat data returned via GraphQL in context of languages in this topic: [IMPLEMENTED] GraphQL default language
How does this work exactly? I can’t find information on it in the docs.
There is no flatData property in my content type, I can only access particular languages - en, pl,…
  • I did add ‘X-Languages’ header, and that makes my response includes only one of the languages, others are null
  • I did add ‘X-Flatten’: ‘true’, but this doesn’t seem to have any effect on flattening the data, still I can access individual languages.
Thanks!
Which version do you use?
I’m using version that is currently hosted by Squidex
Okay, you should have the flatdata property there:
We are also facing a similar issue.
Here is a sample query for ‘article’ an entity in our SCHEMA
The current queries don’t allow for setting the locale of the flatData it is always returned in the default language.
      queryArticleContentsWithTotal(top: 0, filter: "status eq 'Published' and data/slug/en eq 'cool-perks-that-you-need-to-hear-about'") {
        total
        items {
          id
          created
          status
          url
          flatData {
            summary
          data {
            summary {
              zh_TW
              en
[Cloud:Squidex]
App: vannatest
Can there be an elaborate example of an existing demo app where this is well documented as a strong use case for multiple locales being fetched in flatdata or based on specific locales mentioned dynamically
EDIT (updation of support ticket) REQUEST: My reason for documentation clarification is
https://docs.squidex.io/02-documentation/concepts/localization is this approach still supported?
Hey @Sebastian please shed some light on the challenge of flat data content with language permutations for GraphQL query stated above ?
As described in the docs:
But please note that it only works with a real client token, not with your personal token, because this token that you see in the Chrome logs is for the UI
