- [ x] Documentation issue or request
api calls logs can only download ,but can not be seen in the stdout
api calls logs can be seen in stdout
- [ x] Self hosted with docker
- [ x] Chrome (desktop)
- [ x] Edge
api calls log can download from here .
but when i use : kubectl logs squidex-pod ,to see the log ,i can not find api calls log .
so how could i get the api calls log from the stdout ?
I see log statements like the following in my logs:
"logLevel": "Information",
"message": "HTTP request executed.",
"elapsedRequestMs": 9,
"filters": {
"userId": "62cc2f2d4f0e600cfd47fbd9",
"costs": 0
"timestamp": "2022-07-12T08:27:36Z",
"app": {
"name": "Squidex",
"version": "1.0.0.0",
"sessionId": "a06a57e8-e751-4e4f-b821-3fdd8533c526"
"web": {
"requestId": "00-aba0823af5fe622d0351d4db47a2018b-5faf6a6c4ebb15cb-01",
"requestPath": "/notifo-sw.js",
"requestMethod": "GET"
yes , when use kubectl logs squidex-pod ,you can get this kind log , that’s right .
but when you download api calls log ,the log looks like this :
so , i am asking could i use kubectl logs squidex-pod to get api calls log just like the download api calls log ?
I have no idea, this is more a kubernetes question. But why do you want to do that? You should have a logging infrastructure anyway, like elastic search or so. Then you can search in the logs, create charts, alerts and so on.
currently ,when i use kubectl logs squidex-pod , i can get the log just as you showed above , but all the log ,the app name are “squidex” ,but no app name “my-app” as the download api calls log showed .
You could extract that from the URL, it was never relevant for me.
