How to add meta description in my blog?
I want to add meta description in my blog. But I can’t. Help me.
Are you talking about the blog sample? What exactly is the problem?
I want to change meta description in my blog for SEO friendly. But i cant find any options.
I still have no idea what you are talking about. Which blog? Do you use the sample? How is your schema structure?
Anything in Squidex is driven by the schema. When you need a meta description you have to add a new field to your schema and then bind this field in your blog to the description tag. How you do that depends on your frontend framework.
Please put as many details to the blog post as possible. I cannot guess what the problem might be, when I just a get a “help me”
https://www.johnnykspowersports.com/blog/how-to-check-tire-pressure
I send you my blog url and meta description source code. I want to change this meta description. I cant find any options from ari-cms. kindly help me.
I cant find on-page seo options from any web page or blog for google search result improvement.
I still don’t know what you are talking about, sorry.
You have to update your schemas. Squidex does not generate the frontend, it has nothing to do with it, it only provides the data and then it is your job to use the data in the correct way.
