Please guys I am trying to host squidex locally on mac and check the platform.
Please I am not able to run it
1.Running Docker locally.
2. Installed Certificates
3. And error always popups when I start backend.
4. Running frontend on the localhost:3000 gives me screen below and any time I click the login popup pops and disappears immediately.
Please would you advise steps to host it locally step by step? I am sure I am missing smt.
Tried to connect to mongodb using âMongo Compassâ
but not sure what to put into connection string
mongodb://[USER_NAME]:[PASSWORD]@localhost:27017?authSource=Squidex
thx
If you use a local mongodb without username and password you can use the defaults, otherwise your connection string should be okay, but I am not sure if you have not to use authSource= admin or so.
thanks a lot for the answer pls how should the connection string look like? Please what are the defaults? I tried as well mongodb://@localhost:27017 but compass asks me âno user name providedâ. Wherefrom do I take username and password?
How have you installed mongodb?
I downloaded your docker and running it.
That should just work, you do not need username and password, just the default connection strings that are already configured.
Btw: Use https://localhost:5001 as describe in the docs: https://docs.squidex.io/01-getting-started/contributing-and-developing/developing
Many thanks I followed this. Basically what i did is just downloading squidex-master and docker. Running docker and running both FE and BE. Is there some setting for clustering i can adjust? Would love to try squidex love the idea of using orleans.
A timeout occured after 30000ms selecting a server using CompositeServerSelector{ Selectors = MongoDB.Driver.MongoClient+AreSessionsSupportedServerSelector, LatencyLimitingServerSelector{ AllowedLatencyRange = 00:00:00.0150000 } }. Client view of cluster state is { ClusterId : â1â, ConnectionMode : âAutomaticâ, Type : âReplicaSetâ, State : âConnectedâ, Servers : [{ ServerId: â{ ClusterId : 1, EndPoint : âUnspecified/localhost:27017â }â, EndPoint: âUnspecified/localhost:27017â, ReasonChanged: âHeartbeatâ, State: âConnectedâ, ServerVersion: 4.4.3, TopologyVersion: { âprocessIdâ : ObjectId(â603407d8b8de424adebb28afâ), âcounterâ : NumberLong(0) }, Type: âReplicaSetGhostâ, WireVersionRange: â[0, 9]â, LastHeartbeatTimestamp: â2021-02-22T19:40:53.4876280Zâ, LastUpdateTimestamp: â2021-02-22T19:40:53.4876290Zâ }] }.
Can you show me the yaml? Perhaps I have done something wrong.
thanks this is printscreen of mongo yaml.
Can yoju remove the ââreplSet -rs0â part and restart with docker-compose up -d?
