Hello,
We want to quickly try out a new Custom Editor and the idea came up to host it in the Assets (we usually deploy applications to host them).
I came across a small comment from 5 years ago that says it is possible: [IMPLEMENTED] Custom Editor URL Administration - #2 by Sebastian
However there is no mention of this in the documentation for Custom Editors:
Is it possible but just not encouraged hence not being in the documentation?
All the examples use a single HTML file with inline JavaScript, but a lot of our custom editors are applications with multiple files that we target with a folder path, for example: https://<custom editor application URL/customeditors/angularclassiceditor/
If we do host in Assets is it simply a case of using a relative URL to a folder? Or is it that it just defaults to finding an HTML file so that above URL is the same as having:
https://<custom editor application URL/customeditors/angularclassiceditor/app.component.html?
Presumably relative paths within that HTML file in Assets would need to match the layout within Assets and so we could make use of that for shared libraries etc, so:
- Assets
- Custom Editors
- Shared Libraries
- Custom Editor A
- Custom Editor B
- Custom Editors
Hope that all makes sense, turned into a general inquiry with a few small questions within!
