- [ ] Used code blocks with ``` to format my code examples like JSON or logs properly.
@Sebastian Is Squidex HIPPA Compliant? If Yes then what configuration settings are? If not then how we can make it HIPPA compliant?
Does Community version works with MongoDB Enterprise version?
- [x] Self hosted with IIS
Version: [LATEST]
- [x] Chrome (desktop)
