Help with Remirror Rich Text Editor
Investigating using the Remirror editor Squidex supports but need some clarity on a couple pieces, and not finding clear docs.
Right now what I would like to do is…
  1. Hide some of the button options available by the editor (IE: the H1)
  2. Get some clarity on what the Html button does. Whenever I use this I always get an error saving “invalid rich text”. I don’t believe this is a bug, rather I’m just confused at how to use this feature in the editor.
  3. Get some clarity on if its possible to add our own extensions to this editor? Whether take advantage of a feature remirror already offers like tables, or create our own (IE: ability to add youtube video, ability to define custom designed section, etc)
Old docs for the cke classic editor gave some good examples on how to customize. My hope is its possible to customize and I’m just missing a key doc that I’m not finding with search. As well, hoping the customizing doesn’t make me lose great features you built in to make remirror and squidex more feature rich together (like tie into assets, comments, etc)
Richmirror is not a editor, it is more like a library to build custom editors. Therefore it would be difficult to provide docs here. At the moment, I have not tried to integrate it as an external editor, so you would need a fork at the moment.
This should be easy to todo. Just hide the button in your fork.
  1. Get some clarity on what the Html button does.
The html should allow to insert SOME Html. it is converred to its internal format, therefore you cannot enter any html, only waht gets converted.
  1. Get some clarity on if its possible to add our own extensions to this editor?
You need to fork it and then integrate remirror features. Building something by your own is very challenging.
Thanks for the information, appreciate it.
Still confused by the HTML button.
Trying to insert some html (so team can do table).
If I paste in rich text editor all I get back is text without tags.
If I hit the html button, I can paste my html but the save never works always giving me “Invalid Rich Text”. This happens with my pasted HTML as well as keeping it blank, or adding any text.
I see this happening on the squidex cloud Squidex Headless CMS as well as our hosted squidex on older version.
Just not sure if dealing with bug, or I’m completely doing the HTML button process wrong. Would appreciate some feedback.
Do you have an example html content that you pased it. Just to be sure.
bold
italic
I was trying a basic old
tag but everything fails for me. Some easier examples…
<strong>test</strong>
<b>test</b>
<i>test</i>
I’m guessing I’m missing something simple?
I get it now. It is a bug. The html bug is not registered in the backend as known element and therefore validation fails.
