Helm deploy squidex on k8s , clustering issue
This is the fallback page for all non-existing endpoints. I don’t know why it is not reachable for you.
e.g. this is for my test site and cloud:
follow the log “stackTrace”: " , it seems authentication failed :
squidex/OrleansDashboardAuthenticationMiddleware.cs at ca070830989e67940e9b97643916b18ea3c2c8c1 · Squidex/squidex (github.com)
could you show me your values.yaml , maybe you have some configuration i don’t have .
URLS__ENFORCEHTTPS: false # Set it to true to redirect the user from http to https permanently
is this value can only be false ? when i set it to true , the pod can not startup .
It is a docker-compose config: https://github.com/Squidex/squidex-hosting/blob/master/docker-compose/docker-compose.yml
Usually your proxy who creates the certificate should do it anyway. It is not needed.
  - IDENTITY__GITHUBSECRET=${SQUIDEX_GITHUBSECRET}
  - ASPNETCORE_URLS=http://+:5000
i don’t set those values in helm values.yaml , are those values necessary ?
No, they just disable or enable the login providers. And they are set in the helm chart by default:
hello , are you using appversion 6.9.0 ?
when i set it to 6.9.0 , it report error : ImagePullBackOff
But why does it work for me? I meant 6.7.0 of course.
  "logLevel": "Error",
  "message": "Connection id \u00220HMI9TD6LDFGQ\u0022, Request id \u00220HMI9TD6LDFGQ:00000038\u0022: An unhandled exception was thrown by the application.",
  "eventId": {
    "id": 13,
    "name": "ApplicationError"
  "connectionId": "0HMI9TD6LDFGQ",
  "traceIdentifier": "0HMI9TD6LDFGQ:00000038",
  "timestamp": "2022-06-09T07:50:02Z",
  "app": {
    "name": "Squidex",
    "version": "6.7.0.0",
    "sessionId": "ea28212b-c87e-4fc2-bb5a-7a89643cd96c"
  "web": {
    "requestId": "00-20cf8fa39f68dc75234577c01f5e0945-dd47e049d8335340-01",
    "requestPath": "/signin-internal",
    "requestMethod": "GET"
  "category": "Microsoft.AspNetCore.Server.Kestrel",
  "exception": {
    "type": "System.Exception",
    "message": "An error was encountered while handling the remote login.",
    "stackTrace": "   at Microsoft.AspNetCore.Authentication.RemoteAuthenticationHandler\u00601.HandleRequestAsync()\n   at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)\n   at NSwag.AspNetCore.Middlewares.OpenApiDocumentMiddleware.Invoke(HttpContext context)\n   at Squidex.Web.Pipeline.LocalCacheMiddleware.InvokeAsync(HttpContext context, ILocalCache localCache) in /src/src/Squidex.Web/Pipeline/LocalCacheMiddleware.cs:line 28\n   at Microsoft.AspNetCore.Localization.RequestLocalizationMiddleware.Invoke(HttpContext context)\n   at Squidex.Web.Pipeline.RequestLogPerformanceMiddleware.InvokeAsync(HttpContext context, ISemanticLog log) in /src/src/Squidex.Web/Pipeline/RequestLogPerformanceMiddleware.cs:line 54\n   at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpProtocol.ProcessRequests[TContext](IHttpApplication\u00601 application)"
It is the same error, but thanks for the logs.
You could try docker tag dev-6923
