But in the chrome network tab you see the redirect uri with “http”. How is the iframe opened?
you means this redirect_uri ? i don’t know why it becomes this http mode , what i am visitting is in https mode .
Which version do you use? Perhaps it is an old bug, that has been fixed already.
image:
repository: squidex/squidex
tag: “”
pullPolicy: IfNotPresent
is this the lastest version ?
It is 5.9.0. https://squidex-qa.dev.connext.elco-cloud.cn/api/info
Change the tag to 6.7.0. Better to use a concrete version.
apiVersion: v2
type: application
description: Squidex CMS
version: 1.3.0
appVersion: “5.9.0”
home: https://squidex.io/
keywords:
- cms
- headless-cms
- mongodb
- csharp
- asp-net-core
- asp-net
sources:
dependencies:
- name: mongodb-replicaset
version: 3.9.6
repository: https://kubernetes-charts.storage.googleapis.com/
condition: mongodb-replicaset.enabled
if i change the app version , do i need to change mongodb version ?
it works , i change the appversion to 6.7.0 , the web console is working ,no more errors .
thank you for your help .
No, it is not. Please check the logs again and post them as code block (I will not read them otherwise) or file if they do not fit into a single answer.
how could i use CODE BLOCKS. there is nowhere to choose CODE BLOCKS
CODE
aka preformatted text.
Thx. I will dig into that.
Hello , any update for the issue ?
I cannot reach this URL and I do not know why. I just installed 6.9.0 myself and it was working fine.
identity-server/.well-known/openid-configuration ,
in squidex pod ,what’s the path of this file : openid-configuration ?
in squidex pod , under /app folder i can not find the folder identity-server .
It is not a file, it is an API endpoint.
ok , so how could i help to debug this API endpoint ?
No idea right now, sorry. Perhaps there is something in the logs.
in the squidex pod , i can curl https://squidex-qa.dev.connext.elco-cloud.cn/identity-server/.well-known/openid-configuration , and it works .
is there any configuration to limit this API endpoint only accessable via internal network ?
