GraphQL sorting on fields with dash in name
When querying content through the GraphQL API I can’t find a way to express an order by on a field naming with a dash:
ordering using data/slug/iv desc works fine, but doing so using data/publication-date/iv desc result in the following error:
Failed to parse query: Syntax error at position 17 in 'data/publication-date/iv desc'., for query: ?$top=2&$skip=0&$orderby=data/publication-date/iv desc.
How should I write my query for this to work ?
Thank you
Ok, I found that you need to replace dash characters by underscores in that case
Yes, exactly. It is a graphql restriction.
