Using Squidex GraphQL filter with a symbol like & converted to %26 is not finding the text on content. I have a content created with a some text fields and HTML field. When I try to find a content filtering by some of those fields and on the text I have and & it does not get the data.
It should find the text I am looking for with the symbol
- Create a schema with some text fields. One of them like HTML
- Add on the content text like something&other
- Through GraphiQL search the text something&other on the fields
- It should return the content with that text
- [x] Self hosted with docker
Version: dev-7133
- [x] Chrome (desktop)
On the left there is the query and the result, and on the right there is the content created with Redux&something text
