I am new to Squidex and I’m testing it out to make it the main headless cms to use for making websites.
I’ve tried creating different schemas: a main one for navigation (home, contact, products…) and other ones for contents (articles, heroes, posts…). All the contents have a reference field to the navigation menu(s) where those contents will end up being displayed in the website.
My idea was to get contents through the GraphQL API and filter them by their navigation menu so that I could, for example, request all content for the page “home page”… but I soon discovered that is currently not supported.
I searched in this forum for a solution but I couldn’t find any, is there anything you can suggest me to solve my issue? If I switch to using the REST API would it work for my scenario?
In the case where there’s no solution, how complex do you think would it be to implement a feature to allow deep filtering?
Error while filtering graphql queries for reference data
Return the filtered data
Example of a query without and with the filter:
- [x] Cloud version
