Graphql Flatdata & multilanguage headers
  • [X ] Documentation issue or request
Currently our squidex has 3 languages (IT, EN, FR).
All required fields being called are localizable
Initial call to graphql using X-Languages: it,en,fr and X-Flatten and querying for example:
queryMenuItemContents(filter: “data/isRootItem/iv eq true”) {
flatData{
label
children{
flatData{
label
responds with flatData->label: “Istituzioni”.
However, if i use data or data_dynamic, i end up with this:
“data__dynamic”: {
“children”: {
“iv”: [
“ad8049ae-9d36-4a81-9510-4192a8f9a9cc”,
“cc879e4d-7c72-4809-ae66-7dcf1acb5a51”,
“93c60524-4b5a-40f0-a426-257a239c1cf3”,
“19ecdeb3-abfc-4cf7-998a-6004a120fa01”,
“57549604-f2ae-472c-a010-e081cfaeabf2”,
“04d45944-7ba9-41c1-9987-c1173423cc75”
or
“children”: [
“data”: {
“label”: {
“en”: “Institutions”,
“it”: “Istituzioni”,
“fr”: “Institutions”
I was expecting that calling with flatData it should still respond with
“flatData”: {
“label”: {
Version: 7.23
This is not how flatData works. So you want that only invariant fields are “flattened”?
I was looking at the documentation that you’ve supplied and i was under the impression that using the x-flatten: true with graphql in the header should produce
something like you had posted.
X-Flatten: true
    "data": {
        "description": {
            "en": "FoodCo aims to revolutionize the way we eat. Their innovative products focus on sustainability.",
            "fi": "FoodCo pyrkii mullistamaan ruokailutottumuksiamme. Niiden innovatiiviset tuotteet keskittyvät kestävään kehitykseen.",
            "it": null,
            "sv": "FoodCo har som mål att revolutionera vårt sätt att äta. Deras innovativa produkter fokuserar på hållbarhet."
        "founded": 2019
so i was expecting something like:
"flatData": {
  "label": {
    "en": "Institutions",
    "it": "Istituzioni",
    "fr": "Institutions"
changing from flatData to data in the graphql call and also using X-Flatten i still get the iv
      "label": {
      "contentSchema": {
          "iv": "sezione"
GraphQL is statically typed, you cannot just change the type of a value from an object to a string based on headers or so.
ahh ok.
so i’ll have to post process everything. Thanks
Yes, it is technically not possible. We could introduce new fields, e.g. simplifiedData or so.
