- [ X] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
- [ X] Bug report
Global Custom editors in the Application UI Setting are being influenced by the UI settings in other applications.
Have 11 global custom editors in one application working fine.
Then made an upload to another application that only has a single global custom editor. A day or so later, the first application only shows a single custom editor. It’s not an instance issue that manifests itself.
Recently created a brand new cms application that has no global custom editors. After this past weekend, my 3 other cms application have no custom editors. Must now go reset them one by one.
I basically add 13 custom editors to all 4 apps, to prevent losing them, or downtime to the content editors.
Seems this status issue/behaviour only surrounds these global custom editors.
Global Custom editors are isolated from changes in other cms applications. Unique per app.
Is there a way to define an overarching global editor that could be used by several apps (i.e. cloudinary dam widget for getting image/json from cloudinary - future requests)
Doesn’t manifest itself, but
- [ X] Self hosted with docker on Azure
- [ ] Chrome (desktop)
What to be sure this behaviour is zero’d out, or does not exist on squidex versions > 6.4. Like 7.1+
