Getting wrong values for API request with language header
  • [x] Bug report
Hey!,
We have an Angular application that serves clients all over the world, this is the app url: https://privacy.staging.saymine.io/demo-Tashir-382345068
We’re sending a request to Squidex API in order to get localized values, we’re sending requests to this API: '‘https://cloud.squidex.io/api/content/mine-app/text-manager/8ead23e5-8aea-4fd4-892d-f0b860c6ab64’
we’re sending a GET request with the following headers:
x-flatten
x-languages: ar
unfortunately, we’re not getting the right values from Squidex, we’re getting values for a different language.
we would like to get the correct localized values
Navigate to: https://privacy.staging.saymine.io/demo-Tashir-382345068
select Arabic or any other language, open Network tab in the browser and examine the outgoing API request.
staging & prod
Mine - Privacy Center
  • [] Self hosted with docker
  • [x] Cloud version
  • [x] Chrome (desktop)
  • [x] Chrome (Android)
  • [x] Chrome (iOS)
  • [x] Firefox
  • [x] Safari (desktop)
  • [x] Safari (iOS)
  • [x] IE
  • [x] Edge
What do you mean with other language? Usually it falls back to the master language.
We have multiple languages:
So in order to get values for our labels, we’re sending x-languages header with the user’s local language.
But we’re always getting the same result, feels like we’re getting a cached result… if for example, we’re sending header x-languages: ar we’re getting values relevant for a different language (for instance French)
Due to the fact that we’re talking about a Production environment, we had to make a small patch for the meantime, so we’re sending each request to Squidex with an additional header:
cache-control: no-cache
If we don’t send it, we’re getting wrong values.
Do you use the CDN? Because there is no caching I am aware of. Or do you have your own cache layer?
As you can see in the example Omer shared, we are using: https://cloud.squidex.io/api/content/… which is not the CDN.
We don’t have our own caching layer.
I understand it now, it is the etag system that causes some problems here. I fixed a bug with that and it was causing this issue. Your workaround is correct for now and I hope I can provide a better until end of next week.
