- [ ] Used code blocks with ``` to format my code examples like JSON or logs properly.
Hi @Sebastian
I am trying the start the squidex Admin Panel locally in my system using docker for that I had
used the Below official document
https://docs.squidex.io/01-getting-started/installation/platforms/install-on-docker
Inside that from 3 Types We used Squidex+nginx for reverse Proxy
We also downloaded 2 files
i) docker-compose-nginx.yml
ii) .env files
All the steps Works Perfectly But when i start the docker i get the login screen of squidex but when i click on Login to Squidex Green Button then the pop up doesn’t open and I get 304 error
- [ ] Chrome (desktop)
