- [x ] Read the following guideline: https://docs.squidex.io/01-getting-started/installation/troubleshooting-and-support. I understand that my support request might get deleted if I do not follow the guideline.
I have been using a Contents Client to retrieve multiple menus. The GetAsync method on that client no longer supports a HashSet to retrieve multiple items from a list of id’s.
var hs = new HashSet<string>(Ids);
var menuClient = CreateContentsClient<DynamicContent, DynamicData>("[schema]");
var menus = await menuClient.GetAsync(hs, ctx);
Perhaps this is bad design to rely on the ids, but I would like to not refactor at this point.
Pass in a HashSet of string Ids and return the result.
- [ x] Cloud version
- [ ] Chrome (desktop)
