Get contents with status ARCHIVED using GraphQL
I’m running Squidex 5.5.0.
I’m trying to do the following in Postman but I receive an empty array:
  queryCouponContents(filter: "status eq 'Archived'") {
    id
    status
    etc.
    etc.
    etc.
The above GraphQL query returns:
    "data": {
        "queryCouponContents": []
The same GraphQL query works in GraphiQL inside the Squidex admin UI.
When inside the GraphiQL editor in Squidex i open Chrome DevTools and take the bearer token for that graphql network request and use it in Postman I receive contents with status Archived. But this is obviously not the proper way to do it.
I tried regenerating a new bearer token with Owner, Developer, Reader, Editor but none of them work.
So my question is; what are the steps needed for this to work?
I think I found the solution here: https://docs.squidex.io/02-documentation/developer-guides/api-overview/api#published-items
